Resets all RIP parameters to the default for all VLANs or for the specified VLAN.
| vlan-name |
Specifies a VLAN name. |
All.
Does not change the enable/disable state of the RIP settings.
The following command resets the RIP configuration to the default for the VLAN finance:
# unconfigure rip finance
This command is available on all platforms with a Base license or higher as described in the Switch Engine v33.1.1 Licensing Guide document.
